AustinJerry
Nov 02, 2014Aspirant
C3700 IP Address Reservation Table Full?
I would like to experiment with static IP addresses on my network. However, when I go into Advanced LAN Setup and click on the Add button to reserve an IP address, I get the message that the table is...
AustinJerry
Nov 16, 2014Aspirant
Well, I don't recall being able to find a user-definable IP address lease duration. Certainly it should be something like 7 days. Do you happen to know what the factory default lease duration is?
My home network, which consists of 29 devices, is not that dynamic. Each of my home theater components has a network connection, and it is quite likely that the network interface is powered off when I turn the device off (e.g. my TV). But the TV is turned on every day, so I would expect its IP lease to never expire. But it did, and frequently.
It's too bad that the router behaved in this way, because it has soured me on Netgear devices going forward. Sure, it may have been my fault that it behaved this way, but the factory defaults should have made it more stable.
