Ryan0's avatar
Ryan0
c3700 Secruity Question after Factory Reset
After pressing the reset button in the back, http://192.168.0.1/ asks me for serial number which I provide then asks me to answer two secruity questions. I didn't set any questions. I keep trying to factory reset it but end up in the same page.
  • plemans's avatar
    are you pushing and holding it until the lights flash? usually 7-15 seconds?
    have you tried a different pc/browser?
    • Ryan0's avatar
      Ryan0
      Yes. Held it until green light flashed again.Tried different browser as well.
      Sometimes it doesn't even let me go to the serial number page
      • plemans's avatar
        Make sure the coax is unhooked when you do it.
        Try a different pc and hardwire into it .
        also try going to 192.168.100.1
