JTringali
Jan 27, 2016Tutor
C3700 Traffic Meter Missing
Since Comcast capped our internet I wanted to double check their data numbers. I haven't changed our habits at home, yet the data usage went up every month since October (Oct 245, Nov 303, Dec 385, a...
DarrenM
Jan 28, 2016Sr. NETGEAR Moderator
Hello JTringall
I believe comcast has there own traffic meter that is built into your comcast account on there website.
DarrenM
- JTringaliJan 28, 2016Tutor
They do, but they seem to be using some kind of strange numbers and that's why I wanted to check it with my own router. Other people have seen the same thing, with Comcast's system tracking double the data the router says its using.
- rsarverFeb 03, 2016Aspirant
Comcast does have a meter at www.xfinity.com/usagemeter. However, it does not keep track of individual devices on your network, only total data used during the billing period.
I too am looking for a way to track individual devices on my network to stop from reaching my monthly 300GB comcast cap. Unfortunately the netgear genie states the C3700 does not support traffic meter. Perhaps Netgear technical support knows of a work around?
- JTringaliFeb 03, 2016Tutor
I'm not looking for an individual counter (Windows does that on its own for each PC) I want a TOTAL household data number because I don't trust the Comcast numbers that their tool comes up with. Why would they remove the router's built in traffic meter if they were being up front and accurate with their usage meter? It seems nefarious to me.
- DarrenMFeb 03, 2016Sr. NETGEAR Moderator
JTringali
If you do not trust the ISP tool then you may want to do some googling I am sure there is a free tool out there that will do what you are looking for I do not have any recommendations I have not used any of them.
DarrenM
- frankeezipperJun 05, 2016Aspirant
Do you have windows , if so what operating system, or Apple ad what version. I have a lot of experience in these types of meters , most are free
