cpderic
Feb 28, 2015Novice
C3700 VPN Passthrough
I'm unable to find the correct thread to post this in, and Netgear support has been absolutely terrible. So I am just going to post here. Feel free to move this topic if the correct thread exists. ...
talam
Mar 06, 2015Novice
Try changing the admin password to "password" first.
Then run the script.
It worked in my case. The return code = 0 for me (was 30 before).
Try it.
Try it.
- MbrownSep 11, 2015Aspirant
The tech support was not helpful at all but I'm having the same problem... when I run the hot fix I'm getting ret=0 but I still can't connect to my VPN.
Any suggestions
