ssteers's avatar
ssteers
Follower
Nov 27, 2019
C6220 - Network not showing up on available connections
I have no wireless connection even avialable for me to connect to. All of a sudden it just stopped working last night. I contacted my ISP support and they said that it was something to do with the modem and was not an issue on their end. I do not have any devices with an ethernet port so that isn't something I can check. I've tried holding down the on off button, hitting the reset button but nothing I do brings back my network. It's just not there on the list of available connections.
  • FURRYe38's avatar
    Did you press the reset button for 15 seconds on the modem then release? The default SSID name should appear on a wifi device. You'll need to go into the modems web page and setup the modem again and setup a SSID name and PW.
  • I am having the same issue. I called my service provider and everything on their end is fine , the only thing that my WiFi will work on is my tv , because it is hard wired . My cell phones and my fire stick does not show my router name. An anyone help with this issue plz . Thanks
    • FURRYe38's avatar
      So does the wifi SSID appear in the wifi list on your TV? Can the TV connect to the modem with it's wifi if you disconnect the ethernet cable?
