AnBerez
Mar 29, 2017Aspirant
C6250: DOCSIS -> EuroDOCSIS
Is it possible to upgrade the model C6250 in EuroDOCSIS 3.0?
- DarrenMSr. NETGEAR Moderator
Hello anberez
This is a Docsis 3.0 modem.
DarrenM
- AnBerezAspirant
Hi.
I know it. My provider works in the standard EuroDOCSIS 3.0, so my modem works in the 4DS-1US mode, that is, it is partially compatible with EuroDOCSIS. And if so, then maybe it can work in the 8DS-2US mode (after FW upgrade).
Hello AnBerez
C6250 has not been EuroDOCSIS certified so there is no guarantee how well it will work as there is some differences between the DOCSIS and EuroDOCSIS standards. As far as FW upgrades go there is no manual way to update FW on his unit FW has to be pushed by ISP to the device.
DarrenM
