JimAmber's avatar
JimAmber
Follower
Aug 31, 2022
C6250 Keeps Dropping Connection
I've been having problems with my router for the last couple months.  I am constantly (on the order of 15+ times a day) losing my Upstream connection, and when I check my dashboard, I see that 1 or more channels are no longer locked.  I've done every bit of troubleshooting I can think of, including all the various suggestions here.  I had the Spectrum tech out today and he checked the line, said that it's good up to the house.
One thing I've been noticing (I started looking after I saw where someone had pointed it out on the board) is that, when 1 or more Upstream channels come unlocked, the power on the rest spikes up above 50 dBmV.  Currently all four channels are locked and the power on each is 42.5 dBmV or thereabouts.  Here's a snapshot of the current connection info.  I rebooted the router about 15 minutes ago.
Any suggestions or help would be greatly appreciated.  And any additional info needed, I'll be happy to provide.
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1LockedQAM2561345000000 Hz4.2 dBmV46.5 dB24116
2LockedQAM2562351000000 Hz3.9 dBmV46.1 dB2283
3LockedQAM2563357000000 Hz4 dBmV46.2 dB2679
4LockedQAM2564363000000 Hz4 dBmV46.3 dB1894
5LockedQAM2566375000000 Hz4.1 dBmV46.3 dB24100
6LockedQAM2567381000000 Hz3.7 dBmV45.8 dB16120
7LockedQAM2569393000000 Hz4 dBmV46.2 dB2582
8LockedQAM25610399000000 Hz3.5 dBmV45.6 dB1295
9LockedQAM25621483000000 Hz4.4 dBmV45.6 dB37146
10LockedQAM25622489000000 Hz4.3 dBmV45.4 dB30102
11LockedQAM25627519000000 Hz4.1 dBmV44.9 dB2380
12LockedQAM25628525000000 Hz3.9 dBmV44.5 dB2596
13LockedQAM25629531000000 Hz4.1 dBmV44.5 dB1785
14LockedQAM25630537000000 Hz2.9 dBmV43.3 dB24114
15LockedQAM25631543000000 Hz3.1 dBmV43.5 dB3075
16LockedQAM25632549000000 Hz3.9 dBmV43.9 dB2282
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1LockedATDMA495120 Ksym/sec17800000 Hz42.2 dBmV
2LockedATDMA505120 Ksym/sec24200000 Hz42.7 dBmV
3LockedATDMA515120 Ksym/sec30600000 Hz42.5 dBmV
4LockedATDMA525120 Ksym/sec37000000 Hz42.5 dBmV
1 Reply
  • plemans's avatar
    from the look of it you have line issues. But your logs help confirm that. Got a screen snip of the logs?
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
