I used to pull upstream speeds of 5-10 mbs, now i get 1.5 mbs if im lucky, normally i am at or below 1mbs. Mediacom doesn't seem to know what the problem is. here are my settings and stats. any help would be wonderful. thanks in advance
| Frequency start Value |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. |
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 213000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Configuration File | | | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Provisioned Downstream and Upstream Throughput |
| Type | Throughput | | Downstream Provisioned Rate | | | Upstream Provisioned Rate | |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 16 | 213000000 Hz | 1.5 dBmV | 39.3 dB | 58 | 0 | | 2 | Locked | QAM256 | 2 | 117000000 Hz | 2.8 dBmV | 42.2 dB | 0 | 0 | | 3 | Locked | QAM256 | 3 | 123000000 Hz | 2.7 dBmV | 42.2 dB | 3 | 0 | | 4 | Locked | QAM256 | 4 | 129000000 Hz | 2.6 dBmV | 41.9 dB | 1 | 0 | | 5 | Locked | QAM256 | 5 | 147000000 Hz | 2.3 dBmV | 41.4 dB | 9 | 0 | | 6 | Locked | QAM256 | 6 | 153000000 Hz | 2.3 dBmV | 41.3 dB | 1288 | 4994 | | 7 | Locked | QAM256 | 7 | 159000000 Hz | 2.6 dBmV | 41.5 dB | 25 | 0 | | 8 | Locked | QAM256 | 8 | 165000000 Hz | 2.6 dBmV | 41.6 dB | 9 | 0 | | 9 | Locked | QAM256 | 9 | 171000000 Hz | 2.5 dBmV | 41.4 dB | 0 | 0 | | 10 | Locked | QAM256 | 10 | 177000000 Hz | 2.4 dBmV | 41.2 dB | 1 | 0 | | 11 | Locked | QAM256 | 11 | 183000000 Hz | 2.1 dBmV | 41 dB | 11 | 0 | | 12 | Locked | QAM256 | 12 | 189000000 Hz | 1.9 dBmV | 41 dB | 0 | 0 | | 13 | Locked | QAM256 | 13 | 195000000 Hz | 2 dBmV | 40.9 dB | 0 | 0 | | 14 | Locked | QAM256 | 14 | 201000000 Hz | 2 dBmV | 41.2 dB | 0 | 0 | | 15 | Locked | QAM256 | 15 | 207000000 Hz | 1.5 dBmV | 41 dB | 0 | 0 | | 16 | Locked | QAM256 | 1 | 111000000 Hz | 2.9 dBmV | 42.1 dB | 22 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 36500000 Hz | 41 dBmV | | 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 29500000 Hz | 40.5 dBmV | | 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 22500000 Hz | 39.3 dBmV | | 4 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Current System Time:Sun Mar 19 00:50:27 2017 Show Statistics | | System Up Time 11:28:48 | | Port | Status | TxPkts | RxPkts | Collisions | Tx B/s | Rx B/s | Up Time | | WAN | Link Up | 74269 | 1843856 | 0 | 720 | 16523 | 11:27:53 | | LAN1 | Link Down | 0 | 0 | 0 | 0 | 0 | -- | | LAN2 | Link Down | -- | | LAN3 | Link Down | -- | | LAN4 | Link Down | -- | | WLAN/2.4G | 54M | 21049 | 51804 | 0 | 94 | 206 | 11:28:48 | | WLAN/5G | 1.3G | 33792 | 48431 | 0 | 395 | 166 | 11:28:48 |
