igace1's avatar
igace1
C6250 Wifi Dropping With Strong Signals
My wifi connection has been dropping every minute or so.  I currently have the C6250 cable modem router. My firmware is V1.02.01. My provider is comcast. The router is directly connected to the coax with no splitters. The items that are hard wired through ethernet don't have any connection drops.  The devices that are using wifi are typically located about 5 feet from the router.  Comcast claims there isn't anything wrong on their end. Any help would be greatly appreciated!
  • FURRYe38's avatar
    • igace1's avatar
      igace1
      Thanks for the reply! I'm on channel 1 for 2.4 Ghz and 36 for 5 Ghz. Unfortunately I live in a large building so have quite a few wifi neighbors (20+).  I have done a factory reset but it didn't make a difference.
      • FURRYe38's avatar
        Try channels 6 or 11.
        Do you have any power output adjustments under Under Advanced Tab/Advanced Settings/Wireless Settings?
