earhartt
Aug 11, 2023Aspirant
C6250
In the last 60 days, my router/modem will not stay connected. I loose internet mutliple times a day. Thinking it was a Service Issue, I had Spectrum come out TWICE and all is fine on their end. They think there is something wrong with my router/modem device. When I log in, it says my firmware is up to date but even still, there is no where that allows me to update it. I am not sure what to do or try. I have done multiple factory resets as well. It's less than 3 yrs old and just randomly started happening. I also downloaded the Nighthawk App and it says the firmware IS out of date but there is no way to update. I am lost. Can anyone suggest something else to try??
What channel configurations are currently set on the router?
What channels are you using?
Any Wifi Neighbors near by? If so, how many?Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
