davidbjbrooks's avatar
May 09, 2022
C6300 – AC1750 WiFi Cable Modem Router. i bought used works good . but i cant log in ! to change
1 Reply
  • plemans's avatar
    What error are you getting?
    did you factory reset it and install it yourself?
    To reset, push and hold rest for 7-15 seconds while powered on
    then follow the install guide.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
