jdlr
Jan 22, 2018Aspirant
C6300 - Cannot perform firmware upgrade - GUI missing
Hello, I am trying to do a firmware upgrade on my C6300 router. I have tried going to this website for instructions: https://kb.netgear.com/000053268/R6300v2-Firmware-Version-1-0-4-20 The site...
antinode
Jan 22, 2018Guru
Generally speaking, you can't.
https://community.netgear.com/t5/x/x/m-p/1490471
> I have seen on some forums that the ISP needs to perform the firmware
> upgrade, but the issue is, this is my personal router.
Doesn't matter. You still can't. If you search around, then you
should be able to find similar responses from actual Netgear agents.
> Does anyone know a simple workaround to this issue?
Define "simple". Contact your ISP.
jdlr
Jan 23, 2018Aspirant
Thanks for the reply. So I purchased a router from bestbuy and I cannot perform upgrades because only a ISP, that shouldnt have access to my personal router, is allowed to...great product Netgear.
With that being said, I am trying to connect this cable router directly to the coaxial feed from my Spectrum internet. I was on the phone for 3 hours yesterday with tech support and the signal could not sync...it would lock in but would not sync, therefore I could not get internet connection. The tech said that I should try to perform a firmware upgrade, since Spectrum says it should be at V2.01.22, when my current firmware is at V2.01.18 (src: https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router).
Should I keep troubleshooting with Spectrum?
- antinodeJan 23, 2018Guru
> [...] only a ISP, that shouldnt have access to my personal router, is
What if it's not Netgear's decision?
https://community.netgear.com/t5/x/x/m-p/1354161#M9935
Have you another option?
