petewatterschat
Mar 27, 2017Follower
C6300 and NAT Loop Back
NAT Loop Back - a mobil device can use the WAN address for both local LAN access and Remote Access Does the C6300 support this and is there a spec sheet that states this. I have not purchased...
Retired_Member
Mar 30, 2017Even with the latest firmware on the c6300 from TWC / Spectrum, there is no option for NAT loopback. You are better off getting a dedicated cable modem, and separate wifi router for this purpose. If you are going higher than 100mpbs service, get a higher end newer version of this unit. Other than that, i can the c6300 is a stable unit which has provided solid performance, no disconnects, very few reboots, and works with most wifi devices. Good luck with the other brands, i just went through 4 high end routers and the highest rated arris modem, I found too many issues, and I can work around my NAT loopback needs.
