lowdrag's avatar
lowdrag
C6300 and Windows 10 disconnects frequently
Never had a problem with my Windows 7 installation.  Since upgrading to Windows 10, the internet disconnects several times a day.  Usually fixes itself when I run diagnostics, but must reboot from a ...
  • lowdrag's avatar
    lowdrag
    Oct 03, 2015
    The 2nd link down seems to have fixed the problem.  It is to disable "receive side scaling" on the modem.  For more details, see the 2nd link.
    Thanks for all the help.
