lowdrag
Oct 02, 2015Aspirant
C6300 and Windows 10 disconnects frequently
Never had a problem with my Windows 7 installation. Since upgrading to Windows 10, the internet disconnects several times a day. Usually fixes itself when I run diagnostics, but must reboot from a ...
- Oct 03, 2015
The 2nd link down seems to have fixed the problem. It is to disable "receive side scaling" on the modem. For more details, see the 2nd link.
Thanks for all the help.
lowdrag
Oct 03, 2015Aspirant
Babylon5
Oct 04, 2015NETGEAR Employee Retired
OK, that’s great, but just one last point to be clear. That setting has nothing at all to do with the modem, it is a property of the Ethernet driver/adaptor within your PC, and could potentially affect any kind of Ethernet connection your PC makes.
- lowdragOct 04, 2015Aspirant
Yes, Sorry, I misspoke, I meant the adapter in the PC.
Thanks again for the all the help
