DanYingling's avatar
DanYingling
c6300 cable modem and router. and r7000 nighthawk dsl modem and router
I'm having internet issues. i have comcast cable internet and with the c6300 hard wired to computer
my speed is around 236mbps download and around 15mbps upload. but on my xbox im only
getting around 20 download. and it is hard wired. up for any ideas. cable modem has been reset, i feel
like i have done everything
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello DanYingLing
    If other devices are getting full speeds have you tried to swap out the Ethernet cable or try to connect the xbox via wireless and see if its getting faster speeds?
    DarrenM
    • DanYingling's avatar
      DanYingling
      i have tried diffeent cables and wireless make no difference. tryed to set up port fowarding and idk if i did it right
      but that didn't help either. wiped my xbox and reset router to factory spec. none of which did anything to help.
