Jawsh's avatar
Jawsh
Follower
Feb 10, 2018
C6300 Daily Random WiFi dropouts, Wired works fine.
Firmware Version: V2.01.14
Been dealing with this issue for a few weeks now.
My C6300 will randomly drop WiFi entirely, no devices will show my SSID in their available list.
On the Router Web-Interface, it shows the 2.4/5Ghz channels both as Channel 0. Changing the channel does nothing, and neither does starting and stopping WiFi service. The only thing that solves this problem is a complete hard reset which takes around 3 minutes and is aggravating.
My Event Logs also show a daily T3 Timeout, but I have yet to be able to correlate that with the Wi-Fi drop. I never lose internet connection on my desktop which I have connected directly to the modem, so it's a bit difficult to tell when these drops actually happen and if they were caused by a T3 timeout.
In addition to that, the Wi-Fi drop does not associate with any new device turning on or connecting to the network, just occurs randomly.
I've also tried a second C6300 (Thanks Amazon!) and was met with the same issue. Is this model just ridiculously buggy? I set up my parents with the same ISP but with a slightly cheaper Modem/Router combo and they have had no issues.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to factory reset the modem and connect it up to the coax again?
    DarrenM
