ramseyn
Apr 25, 2017Follower
c6300 DHCP not assigning internal IPs
Hello everyone, The above modem suddenly stopped internal IPs. Well, it's kind of weird. I just had Spectrum (formerly Time Warner) come out and check the connection, everything is 100% working ...
DarrenM
May 05, 2017Sr. NETGEAR Moderator
Hello ramseyn
I would suggest factory resetting the unit and do your setup again and see if it has the same behavior. And if it is a hardware issue you should have a 1 year hardware warranty and you would contact support for that.
DarrenM
