spencerx
Nov 20, 2015Follower
C6300 DoS Attacks
I've been having some awful lag spikes/ping issues for a while now. I've pretty much had everything done possible, which led me to buying this router/modem and having a tech come out and fix a bunch ...
JamesGL
Nov 21, 2015NETGEAR Employee Retired
Hi spencerx,
Base on the logs you have provided, it shows that the problem is mostly with your ISP. I would suggest if you will contact your ISP to provide you their own modem for testing purposes. This is to isolate the issue check the line of your connection.
