cfocats's avatar
cfocats
C6300 Drops Wifi every month
I am on TWC/Spectrum and Modem loses WIFI , both 2.4 and 5G once a month and a reboot or power restart fixes the issue. The Firmware is changed when this happens to 2.01.18 and after I reboot unit, firmware is now 2.01.22. Called TWC support and they don't even understand how a cable modem works, and claim that because it user owned, call Netgear
Anyone know how to block the FW change?
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    FW should not go back and forth. Are seeing that? It should be on 2.01.22 or higher.
    how often can you see the issue?
    • cfocats's avatar
      cfocats
      Happens once a month and when it does I lose WiFi I look at the router and I see that the firmware is at. 18 and then I reset the router or power reset and it goes back to. 22
