Sloy
Aug 03, 2015Tutor
C6300 Frequent disconnects
Seems to be a common topic here, but don't think I've seen a definitive answer so gonna try again. Purchased a C6300 because it was (seemingly) the best modem / router out there supported by Comc...
DarrenM
Aug 01, 2016Sr. NETGEAR Moderator
Hello Thehawk
Can you describe the issues that you are having is it the wifi dropping or the modem dropping Internet?
DarrenM
cybrmstr
Aug 08, 2016Tutor
Well from searching around these disconnects are a design issue and in sure netgear isnt going to do anything about. Darren the administrator seems like hes trying to help but based on the number of people that have submitted the EXACT same issue there isnt a solution and Im guessing that darren is allowed to tell you that.
I guess its time to get something from Cisco.
