Sloy
Aug 03, 2015Tutor
C6300 Frequent disconnects
Seems to be a common topic here, but don't think I've seen a definitive answer so gonna try again. Purchased a C6300 because it was (seemingly) the best modem / router out there supported by Comc...
tensleep80
Jan 20, 2017Aspirant
This is a bit depressing - I am having the same wifi dropout issues, so add mine to the list of problem routers. C6300 V2.01.14. This device was supposed to be plug and play - I have better things to do than learn how to be a router technician.
tensleep80
I just finished checking for new updates for the router, it is current. I tried several soft resets and let the router try to fix the wifi on its own. I also tried the hard reset button once, with no success, then finally unplugged the DC power supply and that did the trick. This is a rather frequent series of events, and it comes in bunches. I can rock along just fine for a month or two, then whammo - I have lots of trouble for a week or two. This is probably the third or fourth spat of problems since I purchased the modem last May. I am using more devices - just added a Nest, a Google Home, a Pixel phone and a 4th Chromecast device. However, I expected this router to be up to the task.
- Dbrown18Jan 25, 2017Aspirant
Sadly I have been waiting 2 + years for an update to fix the problem with connections dropping but the problem still exists.
- DarrenMFeb 03, 2017Sr. NETGEAR Moderator
Hello Ssamarron
Have you ran speed test and packet loss tests to see if you can find why the lag is happening you may also want to check the logs of the modem.
DarrenM
- PhilthyMMar 20, 2017Star
Another disgruntled C6300 user!
I read so much about the wireless problems I bought a separate, very expensive access point. Tunrs out the problem is not the WiFi!
I can leave my computer pinging the C6300 from my Mac and it is going via teh new Asus AP, does not miss a beat. After hours of pinging, not a single packet dropped.
At the same time I am pinging various reliable external IPs and regardless of which ones I ping I get around 15% packet loss. So it seems resonable to assume that the connection between my Mac and the C6300 are bulletproof, and the frequent dropouts are between it and the rest of the network.
Given how many others are reporting similar issues, when will Netgear finally acknowledge that this device is inherently faulty and then do something to correct it?
- NETthisGEARApr 07, 2017Apprentice
Please make sure that when you get a new modem to contact your ISP remotely configure and provision it. This is the most common fix. Further troubleshooting is needed if the problems persist of course.
If you don't do this you will not be experiencing lag and disconnects, so if you are reading this and having this trouble.This is the first thing I would address. It could also be an issue with the line itself, or a splitter on the line causing interferrence. So if that is the case then your ISP is going to have to come out and inspect the lines and replace them if needed.
Check your diagnostic logs for T3 and T4 timeouts. If you find them then most likely the issue is what I mentioned above.
The C6300 is great, but I recommend getting the C7000 if you have Xfinity.
- ThoughtAApr 07, 2017Aspirant
I appreciate that you're trying to help, but there are many people now who have had similar problems with the C6300, and doing the basic troubleshooting steps above has already been shown to not work, both in this thread and others.
I'm sorry to say this is a bad modem router. Netgear needs to pull it.
