Sloy
Aug 03, 2015Tutor
C6300 Frequent disconnects
Seems to be a common topic here, but don't think I've seen a definitive answer so gonna try again. Purchased a C6300 because it was (seemingly) the best modem / router out there supported by Comc...
shavini
Jul 09, 2017Aspirant
Hi
its been just 2 months since i got mine. and i'm already having issues... i connect use my TV and laptop both with the router but the wireless keeps dropping all the time. and i can never watch any program on tv properly nor work on my laptop. the wireless keeps goin off . the funny part is all the lights on the router are on but no wireless. and even when i switch it off and switch it on it still doesnt come on. i have to do it about 3 or 4 times to get the wireless to work. sick of this piece of crap. i veen tried everything thats said on this thread. but nothing works.
will best buy take it back if i return??
- PainfullJul 11, 2017Aspirant
Netgear c6300 cable modem/router.
I purchased it brand-new from Best Buy two months ago. Hook it up to Xfinity Comcast activated it, and life was good. Proximally two weeks ago started having a connection problem. Very peculiar set of problems when using my computer and the Wi-Fi function no ethernet, the router would display all green lights solid across the front of the panel, however it would no longer cast my Wi-Fi networks and crash them. This may be a very common problem in this particular forum but I can assure you even the Comcast cabling technicians were stupefied by this behavior. Furthermore the only way to retrieve the networks back was to reboot the router . After several phone calls with X infinity support and Netgear customer support no headway in repairing this problem was accomplished. I purchased another Netgear 6300 and went through the process to properly connect and activate it. Within one hour the router would display the same type of disconnection Wi-Fi station dropping behavior . I think it would be very unlikely to purchase two routers and have them both be duds. Which in my conclusion, leads to the fact that the router has problems either physically or software /firmware related. To correct my problem I purchased a lesser cost Netgear router and with Standard setup and activation, it's performing flawlessly right out of the box. I personally don't want to router that requires expert router knowledge or customer support to install .
If this problem is so widespread Comcast needs to take this off their approval list or Netgear needs to figure out how to fix it. If my first router was still within the return date I would gladly return it.
The whole process between Comcast and net gear concerning this router is a big negative.
Hi Chris,
This is Vaseem from NETGEAR engineering team. I saw you have posted message in our community about C6300 loosing WIFI issues. I got your contact from our community team. Loosing WIFI and router being broken in ~2months is awful and especially when you need reliable internet/WIFI.
https://community.netgear.com/t5/Cable-Modems-Routers/C6300-Frequent-disconnects/m-p/1320526#M9213
We would like to work with you to resolve this issue. I understand you purchased another lower cost router:
1. Would you be able to work with us to resolve this issue? Do you still have bad C6300 device with you? What Router did you purchase to fix the issue?
2. I see XFINITY is your ISP. which region are you located?3. What is the firmware version running on the device?
4. Can you please help us provide these screenshots/logs from your device?
5. What wifi clients did you have problem with? Did the problem happen on one specific client or all the WIFI clients?
Please use below method to capture the screenshots.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
thanks,
Vaseem- PainfullJul 11, 2017Aspirant
That a bunch of questions.
Let me say this. I still have the first router since it is just past return date. The issue is that the first router worked great for months. Then , I believe a firmware update started errors. I go a buy the very same router; and it fails immediately.
My position as a consumer' is not to spend my free time helping netgear solve router problems. I acted with due diligence when I called tech support. Maybe they should have taken the routers problem more seriously rather than making me call back several times to try something else.
See it from my side. I payed over 150.00 u.s. For a router that worked for 3 months. I am not inclined to assist in fixing your product for free. If you want this router to tinker with to figure out its problem you can have it for 150.00 u.s. Dollars and a shipping label. That way I be happier and you'll have this router.
