Ann3's avatar
Ann3
C6300 How do I turn off 5g?
How do I turn off the 5G and turn it on only when I want it. I turn off the radio for 5g and it turns back on when I turn the wifi on in the morning. I turn off wifi at night. I notice if I turn off ...
  • DarrenM's avatar
    Aug 05, 2016
    Hello Ann3
    If you log into the modem by going to www.routerlogin.net then Click Advanced-Advanced Setup- Wireless settings here you can disable and enable the wireless bands.
    DarrenM
