hsustyle
Aug 03, 2016Initiate
c6300 keeps dropping connection
I just bought the c6300 cable modem router to use with Comcast xfinity internet service. I followed the quick installation and activated with Comcast. Now my experience is that every day at random ...
DarrenM
Aug 05, 2016Sr. NETGEAR Moderator
Hello hsustyle
Have you been able to resolve the issue with the wireless or is it still happening if so let me know I will be able to get your case to the right person to help.
DarrenM
- cybrmstrAug 08, 2016Tutor
I am also having this same issue.....ive had the modem about a year or so. It wont run to completion any trace route. Drops the connection all the time recently. By recently I mean like the past few months. Never had a problem till now.
- DarrenMAug 08, 2016Sr. NETGEAR Moderator
Hello cybrnstr
Are you seeing anything in your cable logs when the drop outs are happening? if so could you copy and paste them.
DarrenM
- cybrmstrAug 13, 2016Tutor
Theres no way to completely copy and paste the logs bc of your banging interface which cuts off some of the information.....it cant be save to a text file and it cant be uploaded here. Here is a pathping and a traceroute I uploaded to Blizzard support. That idiot thought I was using wireless. I am wired in and its still dropping.
Tracing route to 199.108.62.157 over a maximum of 30 hops
1 6 ms 9 ms 9 ms 192.168.0.1
2 18 ms 29 ms 29 ms 96.120.77.173
3 18 ms 21 ms 16 ms xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
4 25 ms 29 ms 29 ms be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
5 28 ms 28 ms 20 ms be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
6 40 ms 28 ms 29 ms hu-0-11-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.83.98]
7 27 ms 39 ms 39 ms 192.205.37.33
8 17 ms 25 ms 22 ms cr1.n54ny.ip.att.net [12.122.131.86]
9 31 ms 29 ms 29 ms 12.123.250.133
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Tracing route to 12.129.202.154 over a maximum of 30 hops
1 3 ms 9 ms 3 ms 192.168.0.1
2 20 ms 19 ms 29 ms 96.120.77.173
3 11 ms 15 ms 20 ms xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
4 24 ms 34 ms 21 ms be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
5 23 ms 29 ms 39 ms be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
6 23 ms 24 ms 40 ms hu-0-13-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.85.182]
7 44 ms 33 ms 31 ms 192.205.37.33
8 95 ms 93 ms 91 ms cr1.n54ny.ip.att.net [12.122.131.86]
9 91 ms 97 ms 88 ms cr2.cgcil.ip.att.net [12.122.1.2]
10 97 ms 91 ms 97 ms cr1.cgcil.ip.att.net [12.122.2.53]
11 95 ms 100 ms 93 ms cr2.dvmco.ip.att.net [12.122.31.85]
12 92 ms 93 ms 86 ms cr1.slkut.ip.att.net [12.122.30.25]
14 118 ms 123 ms 148 ms gar5.lsrca.ip.att.net [12.122.85.33]
15 90 ms 97 ms 87 ms 12-122-254-230.attens.net [12.122.254.230]
16 96 ms 99 ms 99 ms mdf001c7613r0004-gig-12-1.lax1.attens.net [12.129.193.246]
Trace complete.
Pathping info
0 RobsASUSI7 [192.168.0.78]
1 192.168.0.1
2 96.120.77.173
3 xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
4 be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
5 be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
6 hu-0-13-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.85.182]
7 192.205.37.33
8 cr1.n54ny.ip.att.net [12.122.131.86]
9 cr2.cgcil.ip.att.net [12.122.1.2]
10 cr1.cgcil.ip.att.net [12.122.2.53]
11 cr2.dvmco.ip.att.net [12.122.31.85]
12 cr1.slkut.ip.att.net [12.122.30.25]
13 * * *
Computing statistics for 300 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 6ms 0/ 100 = 0% 0/ 100 = 0% 192.168.0.1
0/ 100 = 0% |
2 26ms 0/ 100 = 0% 0/ 100 = 0% 96.120.77.173
0/ 100 = 0% |
3 22ms 0/ 100 = 0% 0/ 100 = 0% xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
0/ 100 = 0% |
4 25ms 0/ 100 = 0% 0/ 100 = 0% be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
0/ 100 = 0% |
5 26ms 0/ 100 = 0% 0/ 100 = 0% be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
0/ 100 = 0% |
6 31ms 0/ 100 = 0% 0/ 100 = 0% hu-0-13-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.85.182]
0/ 100 = 0% |
7 29ms 0/ 100 = 0% 0/ 100 = 0% 192.205.37.33
100/ 100 =100% |
8 --- 100/ 100 =100% 0/ 100 = 0% cr1.n54ny.ip.att.net [12.122.131.86]
0/ 100 = 0% |
9 --- 100/ 100 =100% 0/ 100 = 0% cr2.cgcil.ip.att.net [12.122.1.2]
0/ 100 = 0% |
10 --- 100/ 100 =100% 0/ 100 = 0% cr1.cgcil.ip.att.net [12.122.2.53]
0/ 100 = 0% |
11 --- 100/ 100 =100% 0/ 100 = 0% cr2.dvmco.ip.att.net [12.122.31.85]
0/ 100 = 0% |
12 --- 100/ 100 =100% 0/ 100 = 0% cr1.slkut.ip.att.net [12.122.30.25]
Trace complete.
1 192.168.0.1
2 96.120.77.173
6 hu-0-11-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.83.98]
7 192.205.37.33
9 12.123.250.133
10 * * *
Computing statistics for 225 seconds...
0/ 100 = 0% |
0/ 100 = 0% |
2 23ms 0/ 100 = 0% 0/ 100 = 0% 96.120.77.173
0/ 100 = 0% |
3 24ms 0/ 100 = 0% 0/ 100 = 0% xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
0/ 100 = 0% |
0/ 100 = 0% |
5 28ms 0/ 100 = 0% 0/ 100 = 0% be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
0/ 100 = 0% |
6 25ms 0/ 100 = 0% 0/ 100 = 0% hu-0-11-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.83.98]
0/ 100 = 0% |
7 28ms 0/ 100 = 0% 0/ 100 = 0% 192.205.37.33
100/ 100 =100% |
0/ 100 = 0% |
9 --- 100/ 100 =100% 0/ 100 = 0% 12.123.250.133
Trace complete.
- freeradical2Aug 09, 2016Aspirant
Can you help me too please, i have been onto Netgear and Comcast about this and both are blaming each other.
- DarrenMAug 10, 2016Sr. NETGEAR Moderator
Hello freeraical2
When the drop outs happen can you log into you modem and copy the logs you can find them under Advanced-Administration-Logs.
DarrenM
- hsustyleAug 10, 2016Initiate
Hi Darren and others,
I read the following article from Netgear and made the changes suggested. I have not had any problems since. Although I read many forum threads, I did not see this article referenced. I hope this is helpful to other people.
Cathy
