hsustyle
Aug 03, 2016Initiate
c6300 keeps dropping connection
I just bought the c6300 cable modem router to use with Comcast xfinity internet service. I followed the quick installation and activated with Comcast. Now my experience is that every day at random ...
cybrmstr
Aug 08, 2016Tutor
I am also having this same issue.....ive had the modem about a year or so. It wont run to completion any trace route. Drops the connection all the time recently. By recently I mean like the past few months. Never had a problem till now.
DarrenM
Aug 08, 2016Sr. NETGEAR Moderator
Hello cybrnstr
Are you seeing anything in your cable logs when the drop outs are happening? if so could you copy and paste them.
DarrenM
- cybrmstrAug 13, 2016Tutor
Theres no way to completely copy and paste the logs bc of your banging interface which cuts off some of the information.....it cant be save to a text file and it cant be uploaded here. Here is a pathping and a traceroute I uploaded to Blizzard support. That idiot thought I was using wireless. I am wired in and its still dropping.
Tracing route to 199.108.62.157 over a maximum of 30 hops
1 6 ms 9 ms 9 ms 192.168.0.1
2 18 ms 29 ms 29 ms 96.120.77.173
3 18 ms 21 ms 16 ms xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
4 25 ms 29 ms 29 ms be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
5 28 ms 28 ms 20 ms be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
6 40 ms 28 ms 29 ms hu-0-11-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.83.98]
7 27 ms 39 ms 39 ms 192.205.37.33
8 17 ms 25 ms 22 ms cr1.n54ny.ip.att.net [12.122.131.86]
9 31 ms 29 ms 29 ms 12.123.250.133
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Tracing route to 12.129.202.154 over a maximum of 30 hops
1 3 ms 9 ms 3 ms 192.168.0.1
2 20 ms 19 ms 29 ms 96.120.77.173
3 11 ms 15 ms 20 ms xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
4 24 ms 34 ms 21 ms be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
5 23 ms 29 ms 39 ms be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
6 23 ms 24 ms 40 ms hu-0-13-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.85.182]
7 44 ms 33 ms 31 ms 192.205.37.33
8 95 ms 93 ms 91 ms cr1.n54ny.ip.att.net [12.122.131.86]
9 91 ms 97 ms 88 ms cr2.cgcil.ip.att.net [12.122.1.2]
10 97 ms 91 ms 97 ms cr1.cgcil.ip.att.net [12.122.2.53]
11 95 ms 100 ms 93 ms cr2.dvmco.ip.att.net [12.122.31.85]
12 92 ms 93 ms 86 ms cr1.slkut.ip.att.net [12.122.30.25]
14 118 ms 123 ms 148 ms gar5.lsrca.ip.att.net [12.122.85.33]
15 90 ms 97 ms 87 ms 12-122-254-230.attens.net [12.122.254.230]
16 96 ms 99 ms 99 ms mdf001c7613r0004-gig-12-1.lax1.attens.net [12.129.193.246]
Trace complete.
Pathping info
0 RobsASUSI7 [192.168.0.78]
1 192.168.0.1
2 96.120.77.173
3 xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
4 be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
5 be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
6 hu-0-13-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.85.182]
7 192.205.37.33
8 cr1.n54ny.ip.att.net [12.122.131.86]
9 cr2.cgcil.ip.att.net [12.122.1.2]
10 cr1.cgcil.ip.att.net [12.122.2.53]
11 cr2.dvmco.ip.att.net [12.122.31.85]
12 cr1.slkut.ip.att.net [12.122.30.25]
13 * * *
Computing statistics for 300 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 6ms 0/ 100 = 0% 0/ 100 = 0% 192.168.0.1
0/ 100 = 0% |
2 26ms 0/ 100 = 0% 0/ 100 = 0% 96.120.77.173
0/ 100 = 0% |
3 22ms 0/ 100 = 0% 0/ 100 = 0% xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
0/ 100 = 0% |
4 25ms 0/ 100 = 0% 0/ 100 = 0% be-34-ar03.ivyland.pa.panjde.comcast.net [69.139.192.109]
0/ 100 = 0% |
5 26ms 0/ 100 = 0% 0/ 100 = 0% be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
0/ 100 = 0% |
6 31ms 0/ 100 = 0% 0/ 100 = 0% hu-0-13-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.85.182]
0/ 100 = 0% |
7 29ms 0/ 100 = 0% 0/ 100 = 0% 192.205.37.33
100/ 100 =100% |
8 --- 100/ 100 =100% 0/ 100 = 0% cr1.n54ny.ip.att.net [12.122.131.86]
0/ 100 = 0% |
9 --- 100/ 100 =100% 0/ 100 = 0% cr2.cgcil.ip.att.net [12.122.1.2]
0/ 100 = 0% |
10 --- 100/ 100 =100% 0/ 100 = 0% cr1.cgcil.ip.att.net [12.122.2.53]
0/ 100 = 0% |
11 --- 100/ 100 =100% 0/ 100 = 0% cr2.dvmco.ip.att.net [12.122.31.85]
0/ 100 = 0% |
12 --- 100/ 100 =100% 0/ 100 = 0% cr1.slkut.ip.att.net [12.122.30.25]
Trace complete.
1 192.168.0.1
2 96.120.77.173
6 hu-0-11-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.83.98]
7 192.205.37.33
9 12.123.250.133
10 * * *
Computing statistics for 225 seconds...
0/ 100 = 0% |
0/ 100 = 0% |
2 23ms 0/ 100 = 0% 0/ 100 = 0% 96.120.77.173
0/ 100 = 0% |
3 24ms 0/ 100 = 0% 0/ 100 = 0% xe-7-3-0-sur01.newcastle.de.panjde.comcast.net [68.85.193.157]
0/ 100 = 0% |
0/ 100 = 0% |
5 28ms 0/ 100 = 0% 0/ 100 = 0% be-33287-cr02.newyork.ny.ibone.comcast.net [68.86.93.173]
0/ 100 = 0% |
6 25ms 0/ 100 = 0% 0/ 100 = 0% hu-0-11-0-0-pe03.111eighthave.ny.ibone.comcast.net [68.86.83.98]
0/ 100 = 0% |
7 28ms 0/ 100 = 0% 0/ 100 = 0% 192.205.37.33
100/ 100 =100% |
0/ 100 = 0% |
9 --- 100/ 100 =100% 0/ 100 = 0% 12.123.250.133
Trace complete.- cybrmstrAug 13, 2016Tutor
I cant upload the logs I get this message from here
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Log email sent
Decription | Count | Last Occurence | Target | Source
[admin login] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:43:31|0.0.0.0|192.168.0.78
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:53|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:51|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:50|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:48|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:47|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:46|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:44|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:43|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:41|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:40|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:38|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:34|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:33|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:32|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:30|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:28|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:26|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|4|Saturday, 13 Aug 2016 11:36:25|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:18|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:17|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:16|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:14|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|2|Saturday, 13 Aug 2016 11:36:13|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:10|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|2|Saturday, 13 Aug 2016 11:36:09|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:36:05|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|2|Saturday, 13 Aug 2016 11:36:02|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:58|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:56|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:53|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:51|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:49|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:47|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:44|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:42|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:40|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:38|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:36|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:34|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|3|Saturday, 13 Aug 2016 11:35:33|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:28|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:27|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:26|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:24|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:23|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:21|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:20|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|3|Saturday, 13 Aug 2016 11:35:18|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:13|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:11|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:10|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:08|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:07|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:06|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:04|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:03|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:02|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:35:00|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:58|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:56|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:54|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:53|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:51|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:49|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:47|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:46|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:44|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:43|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:41|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:39|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:38|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:37|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:35|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 11:34:31|0.0.0.0|0.0.0.0
[Email failed] Cannot open mail.comcast.net:25|1|Saturday, 13 Aug 2016 11:32:07|0.0.0.0|0.0.0.0
[Email failed] Unable to connect to "mail.comcast.net" port 25.|1|Saturday, 13 Aug 2016 11:32:05|0.0.0.0|0.0.0.0
[Email sent to: robert.l.davidson@comcast.net]|1|Saturday, 13 Aug 2016 11:30:34|0.0.0.0|0.0.0.0
[Email failed] Cannot open mail.comcast.net:25|1|Saturday, 13 Aug 2016 11:26:18|0.0.0.0|0.0.0.0
[Email failed] Unable to connect to "mail.comcast.net" port 25.|1|Saturday, 13 Aug 2016 11:26:15|0.0.0.0|0.0.0.0
[Email sent to: robert.l.davidson@comcast.net]|1|Saturday, 13 Aug 2016 11:24:44|0.0.0.0|0.0.0.0
[admin login] from source 192.168.0.78|3|Saturday, 13 Aug 2016 11:23:11|0.0.0.0|192.168.0.78
[DHCP IP: (192.168.0.61)] to MAC address e4:f4:c6:e6:ef:a6|5|Saturday, 13 Aug 2016 10:58:47|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:41|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:39|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:35|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:34|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:32|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:31|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:30|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:27|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:25|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:23|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:21|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:19|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:17|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:16|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesReceived] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:14|0.0.0.0|0.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1#GetTotalBytesSent] from source 192.168.0.78|1|Saturday, 13 Aug 2016 10:57:12|0.0.0.0|0.0.0.0
[DHCP IP: (192.168.0.61)] to MAC address e4:f4:c6:e6:ef:a6|1|Saturday, 13 Aug 2016 10:56:40|0.0.0.0|0.0.0.0
X-CMAE-Envelope: MS4wfPwqXvHe+LboIh2/0Duj0Ht0CpqdAayfHKtJa5MQn7tErZjlIwpy6uqwI52ykzt8UyRtijTqIslWWRp7OZWJEAzO8V24ys7imURA7xSAgQrBOsEWAof1
0vVXaIMvFoDp5UyXrCZcNCS041iVArn4z9o=- DarrenMAug 16, 2016Sr. NETGEAR Moderator
Hello cybrmstr
If your trying to traceroute Blizzard servers it will time out they mask those hops past there ISP which is ATT to protect there servers from attacks. But what type of drops are you experiencing? does the internet go completely out or do you drop from games.
DarrenM
