Clark01
Jun 08, 2017Follower
C6300 keeps dropping wifi
Hi, I am hoping I can get some help here. This is my second C6300 modem ( I returned the first one for the same issue) and everyday (literally) the modem drops all connected wifi devices but w...
- Oct 16, 2017
I fought this problem for months and finally discovered that the problem for me was the PSP (Power Save Polling) feature of my Windows laptop, which is not supported by this router. In short, when the laptop's wifi adapter would "sleep" in power saving mode, it would basically block all connections to the router, and I would lose all connections (phones etc.) on the 2.5G channel that the laptop was using. To fix this, go to your Device Manager, click on Network Adapters, right click on wireless adapter, click properties, click Power Management, and UNselect "Allow the computer to turn off this device to save power". Mine has worked flawlessly ever since doing this. Hope this helps.
DarrenM
Jun 14, 2017Sr. NETGEAR Moderator
Hello Clark01
Have you tested by changing the SSID to something different or even test if you can see the network by removing the password?
DarrenM
