GVR61
Oct 30, 2018Initiate
C6300 Log under Genie Administrative Advanced Entry
The entry below is on my Log under Advanced>Administrative several times. What does it mean? Also this entry does not contain a valid IP address that I can see. What do the string of characters mean...
GVR61
Nov 05, 2018Initiate
Thank you for your response.
Does this mean I need to turn on my IPv6 Firewall Protection under Advanced>Advanced Setup>IPv6?
jimyjames
Jan 05, 2019Aspirant
FE80 is an ipv6 link local address. Those are not routable outside of their own network. That means it is coming from inside your network and is already inside your routers firewall. So setting up the routers ipv6 firewall would have no effect. It is possible that another device in your network has been compromised and is being used to stage an attack.
