dabeachman
Jun 11, 2016Aspirant
C6300 loses all connections.
Lose all internet connections, hard wired, wi-fi, when I connect hard wire ethernet to my dtv receiver. On time warner, they have sent a tech, replaced the C6300, new one does the same thing. Compute...
- Jun 20, 2016
Well, it was a simple error on my part. After power outage, 6300 reset itself. I had access control on from my original setup. I just overlooked that, odd to me though, that ALL internet was interrupted when the DTV receiver tried to connect, being hard wired.
Even Time-Warner tech ran out of ideas....
Left it unplugged, accessed 6300 menu, turned off access control- allow all to connect- connected, turned access control back on.
Simple, except for a man who has a 47 year career in carpentry...:-)
dabeachman
Jun 12, 2016Aspirant
Solved....
- DarrenMJun 20, 2016Sr. NETGEAR Moderator
Hello Dabeachman
What did you do to fix the issue.
DarrenM
- dabeachmanJun 20, 2016Aspirant
- DarrenMJun 21, 2016Sr. NETGEAR Moderator
Thank you for letting us know sometimes the simple issues are the hardest to find.
DarrenM
