PsychoMadPiper
Sep 22, 2017Aspirant
C6300 MAC Addresses
I bought a refurbished C6300, so the serial# is removed from the Product Label. There was an insert in the box that said to go to the Advanced Settings and provide the ISP (Cox, in my case) with the ...
PsychoMadPiper
Sep 25, 2017Aspirant
Yes, I have a screenshot for the new, current MAC, and the Product Label on the device which shows the original MAC.
vkdelta
Sep 26, 2017NETGEAR Employee Retired
yes, if you have MAC, you should be good.
are you facing any issues?
