jdf1984's avatar
jdf1984
Tutor
Mar 13, 2022
C6300 only solid Green power light
Hello, I woke up this morning with my C6300 only having a solid Green power light on. I’ve tried power cycling it a number of times, but the same thing happens. I can’t even log into the router to troubleshoot. Anyone have an idea about how to correct this?
  • plemans's avatar
    did you try a factory reset? Push and hold reset for 7-15 seconds while powered on
    • jdf1984's avatar
      jdf1984
      Tutor
      I attempted a factory reset, but nothing changed. The power light never changed, and no other lights came on
      • plemans's avatar
        did you try it with the coax disconnected?
        And hold reset for up to 30 seconds?
