marcmgm
Oct 27, 2015Aspirant
C6300 port forwarding, is there a hard fix yet?
Hello, so I've recently tried to utilize the port forwarding function on my C6300 and through trial and error I've combed forums for the program I trying to grant access with, windows firewall, even ...
- Nov 03, 2015
Suffice to say that the RMA'D modem/router worked like a champ. Not only is it updated to firmware 1.02.21, but it also now lets me forward my ports as desired.
Final Analysis: previous C6300 was unfortunately bad out of the box, either from the initial firmware version or an inability to update to newer firmware due to hardware malfunction. On the plus side being very cordial and patient with customer support allowed me to achieve a resolution with maximum efficiency. So for those of you who find yourselves maybe lacking a little remember this, a little bit of patience goes a long way. Number two, don't give up, don't ever give up :smileyvery-happy:
Thanks to the Netgear team for fixing my issue.
marcmgm
Oct 28, 2015Aspirant
So far it is not working at all, any port I try to open has been unsuccessful according to port forwarding checking application or canyouseeme.org
