johnord
Jan 03, 2016Aspirant
C6300 randomly shuts off
The C6300 works fine with celluar devices connected via WiFi. However, my PC could not connect with the router through an Ethernet Connection (I contacted Netgear tech support about this and was told...
DarrenM
Jan 05, 2016Sr. NETGEAR Moderator
Hello johnord
Have you made sure you have all the updated drivers from you pc manufacture for windows 10?
DarrenM
- johnordJan 07, 2016Aspirant
I actually started to write something extremely sarcastic...as if it wasn't one of the first things I had done already.
So the answer, simply, is that the firmware drivers for the adapter are the latest available and the firmware drivers are sent from the ISP to my modem/router.
Please don't ask me if I've turned off the PC for 30 seconds and then rebooted.
- vkdeltaJan 08, 2016NETGEAR Employee Retired
does the router reset if you try to hardwire to the Router (instead of wireless)? If you can check this, please make sure you turn off wireless or disconnect the USB wireless adapter.
- DarrenMJan 11, 2016Sr. NETGEAR Moderator
Johnord
What FW version are you on?
What Service provide do have?
Does the issue occurs when you are connected to 2.4GHz or 5GHz WiFi
DarrenM
