hung-le
Jul 17, 2021Tutor
C6300 remote manager doesn't work
Turn on remote management with port 8554 but when access router from internet got This page isn't working xxx.xxx.xxx.xxx didn't send any data err_empty_response
Hope some one can help
Hi all,
Thanks for your help and suggestion, it 's working now after I change to port 9090 . I'm not sure what is on port 8080 and 8554 that cause the problem. Anyway thanks again .
That's a bit thin on details.
Have you been through all the setup steps needed for remote management?
Tried a different port?
You have posted your message in the section of this community given over to Apps and Services. You might get more help, and find earlier questions and answers specific to your device in the appropriate section for your the C6300. That's probably here:
Cable Modems & Routers- hung-leTutor
Thank for your respone Michaelkenward,
Yes I have been turn on remote management ,allow remote access by every one and port 8554 in Advanced Setup-->Remote Magement. Yes I try port 8080 got same problem .I will try to post it in Cable Modems & Routers like you suggestion .
There are still large gaps in your explanation of what you are doing and where it goes wrong.
Detailed explanations are much more useful than terse "when access router from internet" which could mean many things.
Have you considered "anywhere access"?
- hung-leTutor
Hi all,
Good feedback. Thanks for reporting it. It might help another victim of this in future.
