Steve-51
Nov 18, 2017Follower
c6300 Restrict login from wireless devices
I have remote management turned off - as I understand it - devices connected to the router can log into it. I would like to restrict the login so that only wired devices can log into the router - restricting from all wireless devices. If I had to I would be willing to do it by IP address or MAC address but it appers this can only be done for remote management. Thanks - Steve
1 Reply
- DarrenMSr. NETGEAR Moderator
All you can do is change the password from the default of being password to whatever you want the password to be.
DarrenM
