dknaggert
Jun 06, 2017Aspirant
C6300 Router/Modem stops working - needs reboot
My router stops working while on the internet. When I try to re-connect my home network is no longer available, although others in the neighberhood are. I am able to lock into Netgear75 - when it is ...
DarrenM
Jun 09, 2017Sr. NETGEAR Moderator
Hello dknaggert
Have you renamed the SSID from the default one that came with it? if not I would try that and reconnect to the network also you may want to update your wireless drivers on your PC if you are using one.
DarrenM
