TheTwoEggs
Sep 20, 2016Aspirant
C6300 Schedule Block - Blocking too much
Hi there, I recently got a C6300. I'm trying to set a time block on some devices, and decided to opt for Service Blocking on the Router as it seems like the better option compared to OpenDNS Parent...
DarrenM
Sep 23, 2016Sr. NETGEAR Moderator
Hello TheTwoEggs
Have you tired to make sperate rules instead of using the IP range feature?
DarrenM
- TheTwoEggsSep 23, 2016Aspirant
Hi Darren,
Thanks for your reply.
I just tried this tonight. Same setup, with the devices I want blocked set to IP address 100, 101 and 102, and the rest left on Auto and being given 24, and the devices including the Xbox are still being blocked from connecting to the internet. They connect to the wifi no problem, but no connection can be made to the internet (The same asif you block all TCP/UDP ports on a PC).
Any other thoughts? Really hoping I can get this working.
