doane2u
Aug 23, 2016Aspirant
C6300 Weak/Slow Wifi and wierd Gateway?
My iPhone 6 and the renters down stairs show very weak signals, down stairs it's often times hard to get a signal at all. It is never above the second signal strength dot on the iPhone, even when rig...
doane2u
BTW I was really disappointed in the Netgear tech "help." I couldn't find an answer on the website and finally called the tech. Since I bought the router last December he told me the 90 day tech help is over and I would have to pay $50 even though it has a 1 year warranty. I declined, since I think that is a rip off and also I could hardly understand the guy with his heavy Indian accent, or what ever it was. He gave me a link to a "solution" which was simply pages on the website I had already seen. Also, their email response took a day for his "solution," which really wasn't relevant.
I installed a pretty neat iPhone app that measures signal streength as you walk around. I was surprised at how the signal dropped off after only about 3o feet from the modem with only one interior sheetrock wall and glass windows on the outside walls.. I still think something is wrong with it and any help would be appreciated.
DarrenM
Aug 25, 2016Sr. NETGEAR Moderator
Hello doane2u
Have you tried to set the wireless channel to a signal channel rather than using auto?
DarrenM
- doane2uAug 25, 2016Aspirant
I changed the channel for Netgear21 from auto to channel 10 and it did improve the upload speed considerably, from 26Mbs to 42.5Mbs . How do you tell which channel to select though, and isn't auto supposed to select the right channel? Still a lot slower then my cable connected computer that gets 120Mbs though.
Netgear5g is set to channel 153 with four other channels shown as current. I tested it and I get even worse results, 14.5Mbs down and 5.6Mbs up.. I thought it was supposed to be a lot faster?
Also, I'm still concerend about the default gateway description, is that normal to have that first line I showed above?
Thanks,
- DarrenMAug 25, 2016Sr. NETGEAR Moderator
Hello doane2u
We have a wifi android app called Netgear Wifi analytics that will help find the best possible channels to use as for IOS you will have to look for one. The default gateway looks to be the Mac address of the modem.
DarrenM
- doane2uAug 26, 2016Aspirant
Thanks, Darren, I took a look at the webpage on it and it looks ideal... unfortunately, it won't work with my iPhone or iPad and the Neatgear NetGenie I have that does work doesn't have a lot of those cool features
