LuciferDN
Jul 17, 2017Initiate
C6300 wifi problem
Really tired about the router. it keeps disconnected only my wifi in every 10 to 15 minutes. Anyone can help me solve this problem? My Firmware Version is V2.01.18 The largest packet size from pin...
DarrenM
Jul 19, 2017Sr. NETGEAR Moderator
Hello luciferDN
is it all wifi or certain devices? have you tried to adjust the wireless channel?
DarrenM
- LuciferDNJul 22, 2017Initiate
All the devices. I try to restarted it but it disconnected about 10 mins later.
- DarrenMJul 26, 2017Sr. NETGEAR Moderator
Can you post the logs from the modem?
DarrenM- hawkeye7Aug 10, 2017Aspirant
Same issue. Firmware v 2.01.18. Log files:
Time Priority Description Aug 08 2017 21:47:53 Critical (3) No Ranging Response received - T3 time-out Aug 06 2017 21:23:04 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 06 2017 19:40:33 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Aug 06 2017 19:40:32 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Aug 06 2017 19:34:14 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Aug 06 2017 19:32:13 Warning (5) Lost MDD Timeout Aug 06 2017 19:32:07 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 06 2017 19:14:49 Critical (3) No Ranging Response received - T3 time-out Aug 01 2017 15:26:10 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Aug 01 2017 15:22:19 Critical (3) No Ranging Response received - T3 time-out Aug 01 2017 15:19:47 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out Aug 01 2017 15:19:42 Warning (5) Lost MDD Timeout Aug 01 2017 15:19:38 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 01 2017 15:14:30 Critical (3) No Ranging Response received - T3 time-out Aug 01 2017 14:49:41 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Aug 01 2017 14:47:14 Warning (5) Lost MDD Timeout Aug 01 2017 14:47:08 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 01 2017 14:10:02 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Jul 04 2017 15:47:15 Critical (3) No Ranging Response received - T3 time-out Jun 20 2017 05:15:07 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Jun 20 2017 05:14:08 Critical (3) No Ranging Response received - T3 time-out Jun 20 2017 05:14:08 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Jun 19 2017 11:38:52 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Jun 10 2017 05:52:37 Critical (3) No Ranging Response received - T3 time-out Jun 05 2017 04:53:49 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Jun 05 2017 04:52:38 Critical (3) No Ranging Response received - T3 time-out Jun 05 2017 04:52:38 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Jun 05 2017 04:30:06 Critical (3) No Ranging Response received - T3 time-out Jun 05 2017 00:38:13 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Jun 05 2017 00:37:45 Critical (3) No Ranging Response received - T3 time-out Jun 05 2017 00:17:31 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Jun 05 2017 00:15:11 Warning (5) Lost MDD Timeout Jun 05 2017 00:15:05 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Jun 04 2017 13:34:56 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Jun 01 2017 12:28:18 Critical (3) No Ranging Response received - T3 time-out May 31 2017 13:27:19 Warning (5) Lost MDD Timeout May 25 2017 15:59:14 Critical (3) No Ranging Response received - T3 time-out May 25 2017 12:43:56 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 May 25 2017 12:43:37 Critical (3) No Ranging Response received - T3 time-out May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received May 25 2017 12:43:14 Critical (3) REG RSP not received
