thisisanton
Jan 09, 2016Follower
C6300 wifi randomly dropping on mobile devices
I'm have some trouble with my C6300. WiFi isn't connecting to any mobile devices Phone: Note 4, Note 2, Tablet: Nexus 7 Amazon firestick. But strangely enough it is connecting to the PC in the other room. I called me internet provider, Time Warner and they said my connection is good. The netgear Genie says everything is connected.
It keeps saying obtaining IP, then saved secured. Then starts all over again.
I did a factory reset to the modem/router and upgraded to latest firmware. And am still getting the same results. I called the tech service line and the best he could do/say is that I need to buy a new modem because the one I have is broken. Of course it's right after the warranty ended.
Can't figure this one out. The WiFi works on the PC, but not any mobile devices....
Any help would be greatly appreciated.
- skbz1999Tutor
I have same model and problem just started in past week or so. Windows Desktop, HP Printer, Apple iPad Mini 2, iPhone 5S (x2), Amazon Fire Stick (x2), Amazon Fire Tv, & Vizio Tv all connect with no problems. Only XT1254 Droid Turbo drops 5GHz all the time.
- Scoobylvr5AspirantMe too. Also have TWC.
- goneAspirant
My wifi connection has been dropping randomly but in the last week its been worse. Today it drops everything LAN and wifi. I have to reboot the router several times, even then all the lights are on and I have to log into the modem to turn wifi back on. I called customer support and they offered to sell me a year of customer support as my warrenty has expired. Does anyone have any solutions or having the same problem?
- DarrenMSr. NETGEAR Moderator
Hello Gone
In the Logs of the modem are you seeing any type of errors? You may want to try and factory reset the modem but you will have to redo all your settings. You do this by holding the reset button on the back of the modem for 10 seconds. After that you may want to adjust your wireless channel until you find the best signal.
DarrenM
