rcamp
Oct 28, 2015Follower
c6300 wifi randomly dropping
I have a c6300 that has been pretty solid since installed in August. In the last two week it has developed an issue where the wifi radios appear to randomly turn off (the 2g and 5g lights on the fro...
rcampo
Oct 28, 2015Aspirant
FW = firewall? none
ISP = time warner
- vkdeltaOct 28, 2015NETGEAR Employee Retired
Firmware version
- rcampoOct 28, 2015Aspirant
Try not to use so much jargon and abbreviations.
Firmware version is V1.02.19; not that I can change it -- it is a cable modem; the provider determines the version.
sorry for that.
yeah, Cable devices unfortunately cannot be upgraded by end-user.
so If I understand your problem, you device was working perfectly and you recently started seeing issues. Is that correct?
