jb58
Nov 06, 2016Aspirant
C6300 wireless stopped working after changing Router Mode = No
I have a AC1750 WiFi Cable Modem Router(Model C6300), and followed the Quick Start guide to setup the unit. The unit was activated successfully with TWC, after registering on the NetGear website I fo...
DarrenM
Nov 09, 2016Sr. NETGEAR Moderator
Hello jb58
You may have to use 192.168.100.1 when you set that to no if not try 192.168.0.1.
DarrenM
- jb58Dec 04, 2016Aspirant
Thank you for the response Darren. I don't think the IP address is the problem though, when I clicked 'Apply' the router reset but neither of the Wifi led's were illuminated and there was no Wifi available for me to log on to the router.
- TheEtherDec 04, 2016Guru
Setting Router Mode = No puts it into bridge mode. I would expect Wi-Fi to stop working.
Then how do I get the Wifi to turn back on? I just tried this again and there was no way to turn the Wifi channels on. I guess I'm confused, the user manual says to make this change(as one of the very first steps) and the router appears to stop working.
