jb58
Nov 06, 2016Aspirant
C6300 wireless stopped working after changing Router Mode = No
I have a AC1750 WiFi Cable Modem Router(Model C6300), and followed the Quick Start guide to setup the unit. The unit was activated successfully with TWC, after registering on the NetGear website I fo...
DarrenM
Nov 09, 2016Sr. NETGEAR Moderator
Hello jb58
You may have to use 192.168.100.1 when you set that to no if not try 192.168.0.1.
DarrenM
jb58
Dec 04, 2016Aspirant
Thank you for the response Darren. I don't think the IP address is the problem though, when I clicked 'Apply' the router reset but neither of the Wifi led's were illuminated and there was no Wifi available for me to log on to the router.
- TheEtherDec 04, 2016Guru
Setting Router Mode = No puts it into bridge mode. I would expect Wi-Fi to stop working.
- jb58Dec 04, 2016Aspirant
Then how do I get the Wifi to turn back on? I just tried this again and there was no way to turn the Wifi channels on. I guess I'm confused, the user manual says to make this change(as one of the very first steps) and the router appears to stop working.
You should only make this change if you have a separate router. Do you?
