jb58
Nov 06, 2016Aspirant
C6300 wireless stopped working after changing Router Mode = No
I have a AC1750 WiFi Cable Modem Router(Model C6300), and followed the Quick Start guide to setup the unit. The unit was activated successfully with TWC, after registering on the NetGear website I fo...
jb58
Dec 04, 2016Aspirant
Thank you for the response Darren. I don't think the IP address is the problem though, when I clicked 'Apply' the router reset but neither of the Wifi led's were illuminated and there was no Wifi available for me to log on to the router.
TheEther
Dec 04, 2016Guru
Setting Router Mode = No puts it into bridge mode. I would expect Wi-Fi to stop working.
- jb58Dec 04, 2016Aspirant
Then how do I get the Wifi to turn back on? I just tried this again and there was no way to turn the Wifi channels on. I guess I'm confused, the user manual says to make this change(as one of the very first steps) and the router appears to stop working.
- TheEtherDec 04, 2016Guru
You should only make this change if you have a separate router. Do you?
- jb58Dec 09, 2016Aspirant
No, this unit is the only unit running. I think I see now, with this setup TWC is only providing access to the internet, everything else is up to me. Thank you for your help and patience.
