IllusiveDreams
Sep 22, 2017Follower
C6300 Woes
First off, I am completely not satisfied with the level of support given for these devices or lack there of. I have had nothing but problems with the C6300 I own. It constantly drops wirless signal a...
antinode
Sep 22, 2017Guru
> [...] I cannot login into the admin panel via a wired device or a
> wireless device. [...]
"I cannot" is not a useful problem description. It does not say
what you did. It does not say what happened whan you did it. As usual,
showing actual actions with their actual results (error messages, ...)
can be more helpful than vague descriptions or interpretations.
For example, are you trying to use the router's IP address or some
name like "routerlogin.net" (in some Web browser or other?)?
> I can access some websites if they were cached but new websites just
> won't load which was very odd to me.
Again, there are many kinds of "won't load". Which is this?
That sounds like a DNS problem. That could be a problem with the
router, if you're using the router as your DNS server (which is the
usual way), but your (unspecified) device (with the Web browser) could
be configured to use some other DNS server.
