cwh1947
Jun 01, 2019Aspirant
C6300 WPS process succeeds but no client shown in attached devices
while attempting to attach a dlink camera using WPS the process is done as follows:
I push the softwre button in the wps wizard, then go to the cam and push the client wps button.
The router displays a successful conection and shows the mac address of the camera. When I try to check my attached devices the camera is not in the list. Also downloaded wnetwatcher and it does not appear there either. I need to access the cam to configure a port and port forwarding so I'm at a loss. It does work if I use a cable rather than wireless to connect to the cam configuration page.
I did a total reboot of modem/router and all is ok now.
WPS working as it should. Thanks for suggestions
What happens if you connect the camera to the modem using the WiFi SSID and PW?
