gwpriester's avatar
Apr 07, 2017
C6300
I changed by passcode. All wireless devices are connected except my Roku 3 which does not support WPS. After entering the passcode the Roku fails and say to enter a specific Mac address into the modem router.
How?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello gwpriester
    Have you tried to reset your roku it could be trying to use the old password.
    DarrenM
    • gwpriester's avatar
      gwpriester
      Tutor
      Actually I think it was one of the characters in the password, probably a caret (^) that was the problem.
      Roku said as long as the character appears on their keyboard it should be supported. But apparently this is not the case.
