rosemonttt
Apr 01, 2020Aspirant
C6300v2 Upstream speed awful
Hello. I have been having a ton of issues with my upstream connection lately. I have Cox Communications as my ISP and I have contacted them multiple times but of course they are useless in helping me solve the issue. Anyway, I used to be getting 30mbps+ Upstream and now I can barely exceed 15mbps and often times its stuck below 7mbps. My plan includes 30mbps+on my upstream as well. I also have unlimited data so it isn't the data cap interfering. I was told by my ISP that they are sending and pinging perfectly fine speeds and having nor seeing issues with my equipment. On my gaming and streaming PC I am hardwired and only recently started having this issue. ISP says that it seems to possibly be an internal failure in my modem. I am also using a R7400 Nighthawk router extrernally connected to it. Can anyone analyze the logs and Down and Upstream Channels? I am new to all of this and would like some additional insight on if my ISP is actually right and I need to go buy a new modem or if they're wrong and it's their problem. Thank you much!
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
LOGS:
| Apr 01 2020 23:08:35 | Notice (6) | TLV-11 - unrecognized OID |
| Apr 01 2020 23:08:35 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Apr 01 2020 19:50:09 | Warning (5) | Lost MDD Timeout |
| Apr 01 2020 19:50:05 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Mar 29 2020 19:34:35 | Warning (5) | Lost MDD Timeout |
| Mar 29 2020 19:34:29 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Mar 29 2020 07:49:19 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 28 2020 20:01:53 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 28 2020 20:01:53 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 28 2020 18:02:11 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 28 2020 18:02:11 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 28 2020 17:55:41 | Warning (5) | Lost MDD Timeout |
| Mar 28 2020 17:55:36 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Mar 26 2020 21:10:25 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 26 2020 21:10:25 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 24 2020 16:55:58 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 24 2020 16:55:58 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 19 2020 19:18:03 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 19 2020 14:50:13 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 19 2020 14:50:13 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 19 2020 14:39:29 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 19 2020 14:39:29 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 19 2020 14:21:06 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 19 2020 14:21:06 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 19 2020 14:09:39 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 19 2020 14:09:39 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 15 2020 21:11:45 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 15 2020 21:11:45 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Feb 15 2020 07:31:26 | Critical (3) | No Ranging Response received - T3 time-out |
| Feb 13 2020 16:38:39 | Notice (6) | TLV-11 - unrecognized OID |
| Feb 13 2020 16:38:39 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Feb 13 2020 16:26:20 | Notice (6) | TLV-11 - unrecognized OID |
| Feb 13 2020 16:26:20 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Feb 09 2020 15:26:11 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Feb 08 2020 21:22:19 | Notice (6) | TLV-11 - unrecognized OID |
| Feb 08 2020 21:22:19 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Jan 21 2020 13:49:40 | Critical (3) | No Ranging Response received - T3 time-out |
| Jan 20 2020 23:42:24 | Notice (6) | TLV-11 - unrecognized OID |
| Jan 20 2020 23:42:24 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Jan 17 2020 22:35:11 | Notice (6) | TLV-11 - unrecognized OID |
Remove the R series router and connect PC and your gaming devices directly to the C series mode.
Wire connect your gaming devices to the either modem or router. Its preferred over wireless for gaming.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.Or you can bridge the C modem and then connect your R series router to the modem.
- rosemontttAspirantIf I were to connect my gaming PC to my modem, wouldn’t it interfere with my wifi connection that my mobile devices and Apple TV need to use? I am currently hardwired to my Router (R device). There are no splitters along the line that I know of. I need the router for my WiFi enabled devices that I cannot hardwire.
Connected to the modem wired?
Either shouldn't interfere with other devices...
