Calebscottr's avatar
Calebscottr
C6300v2 Wifi SSID no longer showing
Hi, recently the power flickered and I have experienced a problem where I am no longer able to connect to my wifi on any device. I have called both my ISP and Netgear, which have said there aren't any internet or router problems. Ethernet works just fine, do you have any idea what I can do to get this resolved?
  • plemans's avatar
    Have you logged into the router and checked its ssid/password setup?
    You can hardwire a device into it to connect/access it.
    • Calebscottr's avatar
      Calebscottr
      Hi, yep I've hardwired into it and there doesn't seem to be anything beyond the default there. The SSID is being broadcasted and it is all default name and password.
      • plemans's avatar
        Is it showing enabled?
        What are the wifi led's on the front of the router showing?
        Have you done a wireless scan?
        Or pushed and hold the wifi on/off button for 2 seconds?
