crazylittl3liza
Jan 20, 2023Follower
c6900 wifi router
After factory resetting my router I was finally taken to the page to set it up. I logged into the netgear geni via the browser it took me to without incident. However it allowed me to access 3 different areas then suddenly it started saying cannot access due to insecure security settings with a Mozzila logo. I decided to try using microsoft edge but it did the same thing. So hey thanks to everyone for helping me log into it unfortunately I must report it was to no avail. Any suggestions on what to do now? Oh and the desktop geni app doesn't work with my router.
Thanks in advance
Also now I can't even reach the login page http://www.routerlogin.com/genie_index.htm again, it goes back to netgear.com
absolutely unacceptable- NETGEAR do BETTER!!
1 Reply
- FURRYe38Guru - Experienced UserWhat do you see when you try 192.168.1.1 or .0.1 or 192.168.100.1? Be sure to clear out all browser caches before going to these addresses. MS Edge should work or try Opera...
